Where does the hose go?
New Kent, VA
Ok, i just replaced my valve cover (again, the first time i messed the gasket up :mad:) and i managed to pull a hose from both ends and i dont know where it goes. There is a cluster of vacuum hoses that come off of the manifold right by the throttle assembly. It has four small nipples and one larger one. I have the four smaller ones put in but the larger one i cant tell where it goes. Ill see if i can get a pic put up here in a little bit.
Also, ive searched and found vacuum diagrams out the wazoo for 60s but nothing for a 62. Anyone got one?
Thanks
Matt
ok, heres a little more clarification. In that cluster there are two smaller hoses that run to the throttle body, one that runs to a little valve jiggy over what i think is the charcoal canister, and another one that runs to the air cleaner. That leaves one larger hose to plumb. Im confused because the diagram shows the hose in question but it shows it running to a spot it can barely reach that has a hose already hooked up that i can tell is right (its got old bends from sitting in that position for years). Also, ive got 3 hoses coming off my air cleaner, but the vacuum diagram only has 2 "to air cleaner" notations.
Please help, i want to drive places today.
