I'm installing a set of Dobinsons MRA shocks on my 2019 and there is some interference with the remote reservoir by bracket that I had to modify. In an effort to put together some better instructions for other folks I'd like to see if anyone knows if the portion of the bracket I had to cut off is actually used on any of the US trucks. If it's not then cutting the bracket could be suggested as a good workaround to others, but if it is commonly used I should probably find a different way to go. Circled in red below, but it's normally sitting behind the splash shield. The bracket also secures that fat wiring harness to the right of it.
