I've done this twice (2 different trucks) in the past year. It's not hard. Biggest PITA is the oil pan. Getting it off is harder, getting it back on is a royal pita.
Order the rings and bearings from Pacific Lift Parts. They're in Cali. Make sure you know that your block hasn't been oversized.
For disassembly, drop the pan, pull the head, and push the pistons out through the top. Number them. The notch goes toward the front, by the way. You'll understand when you see the pistons.
The parts should come in a few days. Pull the head, and have it cleaned and checked for cracks. You've got it off, don't be cheap.
Take the pistons and rings to the machine shop. Have the rods mic'd for round and honed if need be. Have the pistons inspected. And have them install the rings. I had mine done for $20/piston.
Borrow a hone from the machine shop and lay a nice cross hatch pattern on the cylinder walls. Just put it in a drill chuck and carefully run the hone up and dopwn the walls 7 or 8 times. Check the top of the cylinder for ridges. If you can catch your fingernail, the ridge needs to be taken down.
Now, what i'm about to say may alarm some, but you don't need a ridge reamer. We're not building race engines. Just take some 120 emery paper and hit the ridge enough to get it flush with the cylinder walls. you may want to do this before the honing so the the hone can erase and scratches you made.
Installing the bearings is pretty straighforward. they're identical top to bottom, and only go in one way. just make sure they're oiled up.
If you've go some bolt protecters for the rod bolts, use them. otherwise be careful not to nick the crank. Installing pistons in the vehicle is a 2 person job. Compress the rings, set the piston into the bore, and gently tap the top of the piston with a rubber mallet until it clears the deck. Be careful not to let the piston get cocked in the ring compressor.
that's basically it.
Good luck, remember to torque the head again after 250 miles.
Rob
