- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,564
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Was this at Goodwill? When the box fell on him?
Snorted coffee out nose. LOL
I grew a mustache looking at itThat Vette made me want to smoke a Marlboro!
He told you that you got cooler cause you sold the Vette....Ha…man I can honestly say I’ve never heard that before. . But thank you ma man. Coming from you that’s truly a compliment.
Shhhh...He told you that you got cooler cause you sold the Vette....![]()
Ha, but I’ll never sell the Z28 which is without a doubt fuc*ing cool as sh*t. I don’t care what anyone thinksHe told you that you got cooler cause you sold the Vette....![]()
Good call. So this would eliminate two clamps (will remove the coupler) along the way. I’ll see if I can find a pic so I know what this should look like.While they’re at it, have a nipple added for the steam lime if you get the radiator reworked.
Great call Ian. I’ll pass that along to the owner. He picked this height but without driving it yet things like this are unknown to both of usYeah buddy, looking good.
I don’t have any input about the radiator but I’ll offer my opinion on that front bumper…
It looks like it wants to come down a hole to even the headlights up top to bottom. The bumper I got from Ben was like the one here and it finally bugged me enough to do something about it. While, yes, it looked better, it also blocked more light than I realized on the bottom.
Just a thought. Hope to see you up north.
Heading for the land tomorrow.
Which front springs did you end up putting on it? Looks like they are the 70 series length; the height looks great!Been slowly working on this LS/62 that a friend in Austin bought from another MUD friend in Hico TX. It’s been slow going but I reduced the 1.5” body lift and in order to keep the 35’s the owner went with a Man A Fre shackle reversal. Has been fun to do but as usual one mod requires several unforeseen mods. Dropping the body has caused interference with the upper radiator hose and the fan shroud. Moved the fan shroud but not a ton of clearance so with the upper radiator hose crossing over the top of the shroud it hits the underside of the hood and then pushes the shroud down into the fan. Plan A (cheapest) is to rerout the hose the best we can. Plan B is to take the radiator in to get the inlet and the fill neck flipped. Truck sits great but we have not been able to take it for a real test drive until we can close the hood.
Also added a Trail Tailor rear bumper (very nice/clean look) As well as an ARB front
@CenTXFJ60 and I talked for a bit when he was working on that truck and HZJ75 spring packs with a couple leaves pulled is the ticket for the front of an SR setup. So are nylock nuts!Which front springs did you end up putting on it? Looks like they are the 70 series length; the height looks great!
Cant tell in the pictures, but one thing I would change about the shackle reversal kit is the front spring pin nuts. If they aren't already, a nylock or a distorted thread lock nut, its a good upgrade. I had mine start to come loose after a few hundred miles of dirt roads last October.
