I did use search here and on the net but no answer ...
What size are the front and rear shock mount studs
I have shock mount studs on my current rear end. However, they are on the leaf spring U-bolt plates.... but I'm using the mounts I have on the axle perch.
I'm installing my conn-ferr leaf spring skids which have no shock studs..
my recently purchased rear end has no shock mount studs on the axle perch as does My current rear end.
Those shocks on my rear end currently are protected above the leaf spring. That's were I want to re-mount my shocks on the rear I'm installing.
I need to know the size diameter, length, thread size, and pitch etc for the studs that I can purchase for the rear end putting in.
Thanks for the direction
