Good afternoon gentlemen. Let me explain the scenario. I installed my 33' tires first with no issues on stock suspension. Two weeks later install my lift kit from slee, diff drop, and replaced both front axles.
Now, I'm experiencing some rough acceleration between 50 to 65mph when I give is some gas about 20% throttle. The rough acceleration occurs only slight open throttle and picks up smoothly when I give it more gas or at WOT. It's the same feeling you get when you'd be at low speeds but have it in a higher gear on a vehicle with manual transmission.
Anyone ever experience this issue? If so, what have you done to fix it?
Thanks in advance.
Thanks in advance.
