What Is This Part? (1 Viewer)
DFW, TX
Anyone know what this is? Recently had my TB, water pump, and drive belt replaced. Noticed this afterward. Front passenger side of motor.
Thanks!
full
full
Looks like the infamous shrunken valve cover gasket...
You need to top off your coolant, too, btw...
Thanks guys! I looked up valve cover gasket on the 4.7 and it seems like loose bolts are very common. I’m hoping it’s just that. I’m pissed the dealer didn’t say anything.
my valve cover bolts were loose... it was because the gasket had shrunk from time as well as being hard as a rock. If you overtighten the bolts to gasket still wont seal where it has started leaking.
Its pretty easy DIY to replace the valve cover gaskets.
