But I still can’t believe anyone drinks that piss.
But I saw it on Yellowstone, all the cool Kalifonian cowboys drink it.
Even though I had already tested my endurance earlier this morning mixing and pouring a dozen bags of concrete in a wheelbarrow, I decided that today would be the day!Did you swap out with the ones included behind the screws?Changed out the jets in the Fuji carb, made a big difference in power. After getting lucky and removing the first jet with the carb in place, the second time I lost it in the bowl and had to remove the carb to tilt it and recovered the lost jet and washer. Drives much better at speed.
Looking good, Mark!As if that wasn’t enough, we’ve had a healthy dose of June gloom this week, and @majdomo has been patiently waiting for me to fab him up some bump stop extensions. I told him that I would break out the welder when I had something else to do.
Some of you might recall me posting up a pic of a wheelwell replacement that I fabbed up in my backyard a couple of months ago, using a Landcruiser brake drum as a jig.even though I had already tested my endurance earlier this morning mixing and pouring a dozen bags of concrete in a wheelbarrow, I decided that today would be the day!
Mock up and tacking ensued. Then I cut a quick freehand arch into a piece of scrap steel and went to work on the missing radiuses.
Two and a half hours later, the driver’s side of the truck finally matches the passenger side. Only took 15 years.![]()
Yes. Primary was larger. Power is noticeably better, However I noticed that it is using significantly increased fuel usage to the point I’m thinking about switching back.Did you swap out with the ones included behind the screws?
Makes sense. Those are intended to be high altitude jets if I remember correctly.Yes. Primary was larger. Power is noticeably better, However I noticed that it is using significantly increased fuel usage to the point I’m thinking about switching back.
Is that an old Man A Fre sand bar I see there?Put my hubcaps back on!
It’s been a long journey.
I had the rims custom made back in 2004. I distinctly remember wheeling them in TX in 2005. Many trips through the Rubicon et al over the next 16 years, I looked at them one day in Death Valley in 2021 and realized that the tires were 17 years old!I didn’t have the time to spend to smooth out all the rock rash and bent lips, so I hit the easy button and had new tires mounted onto a spare set of wheels from my K5.
Life happened, and it wasn’t until two months ago that I finally got the old tires dismounted and started doctoring up the wheels. Planets finally aligned last week, and I got the truck down to the shop and made an appointment with the local off road store to get them mounted.
As the installer groused about how far out of true they were, a little light bulb went off in my head that I had flopped the truck about 10 years ago ( @JLH911 knows when) and that might be part of the problem. Well, they persevered, and I got what are supposedly properly balanced tires (I haven’t hit the highway yet.)
Could just as easily been a Downey.Is that an old Man A Fre sand bar I see there?
I am in love with that TOYOTA font. Thanks for sharing that.Could just as easily been a Downey.
The fact of the matter is that neither of them MADE rollbars. Bars were either from Smittybilt or ConFerr. Mine is a very old-school, and very modified ConFerr.![]()
You’ll probably like this tooI am in love with that TOYOTA font. Thanks for sharing that.
You would be correct sir.You’ll probably like this too
I was honored when Jim was closing the doors on his shop that he gave me these two treasures from his legacy, along with the neon sign.
Then again, Pete Condos bestowed a few treasures on me before he sold ConFerr.
My 40 came with quite a few ConFerr accessories that while I took a few off, I am holding on to them for someone who would appreciate them.
