What have you done to your Land Cruiser this week?
Building 40 a trail buddy. 😁 1979 Toyota truck bed trailer. Swapped a 2 wd axle (5 lug) with another 4x4 axle (6 lug) so my 40 wheels would fit to match. Pressure washed today and getting ready to do a little body work mainly on the tailgate and paint to match. Put the OEM fender flares on and build a rack for the front to carry small generator and cooler and or firewood. Sitting a bit high but I'm about to install a full size 33x10.50x15 BFG tire underneath so that may help. May have to remove a leaf from the springs and or get shorter shackles. Putting together some ideas for the top cover. POR 15 the underside next.
I had one of those and drug it from Vancouver WA to NY and back before giving it away.
What’s going in it? Where did you dig up the mud flap?
More troubleshooting today. I’ll give you one guess as to what caused the smoking wires.
And I found a new spot where coolant is leaking (at the tip of my finger).
I’m also working my way back in the fuel system to see where I’m losing suction so I’ve got 9 feet of fresh line and an old milk bottle full of diesel positioned so I can see it while I’m priming.
It looked like the lines for the sediment filter were backwards. I’m assuming the filter only flows one way, so that would be a problem.
Picked the mud guards up on eBay. Not quite sure yet on the inside. Primarily going to carry camp gear coolers water etc. Maybe some pull out storage trays or stove....IDK yet. Would like to build a top to match the 40's top and put a rack on it for kayak's and bikes.
It was fine. Most of the time I pulled it with a full size truck and it was so small you could not see it. When I towed it with a 3/4 ton and no drop hitch it was so far out of level at speed it swing side to side.
When I did tow it with the Land Cruiser it was fine, never took it off road. Used it to move my stuff from Vancouver back to Green River, WY.
I sheared the ball off with the 1/2 ton Dodge because I jacked knifed it in the street with a load of pea gravel.
When I moved to PA I left it at my Dad's in WY until I moved back to WY and since I was not using it I gave it to the contractor the built our barn.
Do you have a direct link to those?
Also, what brackets are you using to secure/mount them??
No, I just found them on eBay. They did ship from Singapore! The mounts were on the bed when I bought it.
You can do an internet search with the part number and you make get hits other than eBay. Or from Toyota if it is still available.
How is the spring rate with 80 springs ? I have to think a 40 is lighter in the front than an 80.
Best I remember you were building these kits for a 1:1 lift. Is that still accurate?
I’ve been collecting parts for this same swap using 62 series axles.
Thanks for the info and inspiration
Golly, back in 1972, you couldn’t buy Coors Beer east of the Rockies. Two crazy and older friends of mine took his F-250 to Colorado and drove back to Vermont with 20 cases and did it all in a week. Good ole days are long gone…so is he by the way
Also back about then, you could buy Coors in Idaho but not in Oregon. After a river trip my brother filled his kayak with it and made it almost all the way home to Eugene, when in a busy intersection (29th & Willamette), his boat came off the top of his car, with cans rolling everywhere.
Different strokes for different folks I guess. I grew up in the shadow of the Coors brewery. The best thing I can say about it is, they employed a s*** ton of local people. They had their own railroad, fire dept., water treatment plant, etc. But I still can’t believe anyone drinks that piss.
