What have you done to your Land Cruiser this week?
Oops....
I only found out a week after.... backfire on my project
I did this as well.
Turns out I either ate an exhaust valve in the process or had a bad exhaust valve, plus my timing was way off.
Replaced the exhaust valve and had @Thechief86 fix my timing issue and it hasn't come back.
I did this as well.
In my case, I set the wrong timing (at 180 degrees).
After re-installing the distributor, it started working fine.. except the exhaust stopped coming out of the pipe.. ..Hmm
I look under ... and find out why... :)
Finally pulled the tyre off my old steel split rim to change the tube (since nobody else will touch them).
Pretty well stuck on with rust, but pretty doable even on the roadside tbf.
Extra points if you know what model these rims are from!
Rims: Jackman rims??
Edit: Oops, yours are not Jackmans.
Trying to keep the cruiser parts buying on the DL and Summit sends me a large box for a tiny gauge! Thanks a lot… instantly busted. :slap:
please post when you reassemble, I took mine apart three years ago and I forgot how the bolts and washers are arranged.
Highly recommend that while you have the seats out to add extensions to allow more leg room. Extensions for the drivers seat are available from several Mud vendors. I just made extensions for the passenger seat out of steel channel that moved the seat back 2” which is most you can do with OEM seats/brackets.
All those lines for the gas tank vent should fit under the tank cover. And, while I'm not sure exactly how that plastic piece is supposed to mount, and know I am missing a few parts, covers etc., I'm pretty convinced that it needs to be mounted higher than the tank with the hose to the check valve at the highest point.
When I bought my '74, that vent hose with the check valve was routed back into the tank and the whole thing was lying on top of the tank under the metal cover (with an aftermarket plastic tank), and the whole inside always smelled like gas (even parked outside, with the top off, no doors). Mounting that upright, and plumbing as shown in the FSM and my interior lost the constant gas odor.
