I’m also curious if this sped up the wipers at all. Mine seem so sluggish.How long did this take you?
I just got my first 80! So, naturally, I had to drive it around and show all my friends and family how cool I was.What did you do with your 80 this weekend: maintenance, fix, wheel, nothing, new mod??
Me:
Checked air in tires
Change oil&filter 180,000
Fill gas tank
Waiting on box of parts from Beno
We are a visual group ! Picture or it didn't happenI just got my first 80! So, naturally, I had to drive it around and show all my friends and family how cool I was.
Especially when the temps cool down, much like the power windows.I’m also curious if this sped up the wipers at all. Mine seem so sluggish.
We are a visual group ! Picture or it didn't happen![]()
Not long at all. For a straight swap maybe 30 minutes. I was taking my time and cleaning things as I went. I did it under an hour.How long did this take you?
Does the iBooster allow you to increase your braking power above the stock, vacuum based brake booster? And did you wire it up to stock pedal or using one from a tesla?After a couple of weeks finally permanently installed and bled an ibooster out of a tesla model y in the 80. Also took the opportunity to get rid of the abs/ LSVP.
View attachment 4036631View attachment 4036632
So this is probably equivalent from a braking power standpoint since I chose a master with the same 25mm bore as the 80. You may be able to find ones with larger bores that fit on the booster though, but I didn't look very hard.Does the iBooster allow you to increase your braking power above the stock, vacuum based brake booster? And did you wire it up to stock pedal or using one from a tesla?
It's really not that complicated. Only tools you need are screwdrivers to remove the various fittings around the inside of the windshield (A-pillar covers, sunvisors etc.), a 12mm wrench to pull the wiper arms and stubby screwdriver to access the screws on the plinth below the windshield. Oh and a length of cord.Discovered a windshield leak during the recent heavy rains. Initially noticed a wet passenger side floor mat, probably dropped through the dash. Picked up an OEM gasket. Trying to decide if I should find a competent shop that will follow the fsm, or attempt it myself. I lack the experience and tools to tackle this one. View attachment 4036937
You make it sound easy! I may give this a shot on my own, thanks for the tips!It's really not that complicated. Only tools you need are screwdrivers to remove the various fittings around the inside of the windshield (A-pillar covers, sunvisors etc.), a 12mm wrench to pull the wiper arms and stubby screwdriver to access the screws on the plinth below the windshield. Oh and a length of cord.
The adhesive you choose to use will dictate how much time you have. Historically I have used this https://www.amazon.com/dp/B000RW1XCK?tag=ihco-20 but you only have 30 minutes before it starts to go off. Last time I used this stuff which also worked well. https://www.amazon.com/dp/B0182RGDP8?tag=ihco-20
Definitely bring a friend to help.
