Thanks!That is extremely clean, especially if you have been running with leaking valve seals for a long period of time.
Now is also a great time to replace the fuel injector o-rings, pre-emptively wrap the fuel injector harness wiring with fiberglass wrap, as well as replace the fuel pressure regulator (on the fuel rail)
looking further…. might want think about also replacing those heater hoses and heater valve. they look original (other than the blue inlet hose). Might set you back a couple of days getting back on the road, but they are soooo much easier to access with the throttle body and valve cover removed.
The PO (Dogfishlake, AKA Bowfin Cruisers) did a good job on the PM headgasket job ~70k miles ago. The head got a full service at the machine shop, but they used non-OEM seals that failed quickly. ARP Head studs, Valve lash adjusted, Injectors cleaned / re-ringed, as well as wrapping the wire harness and replacing the coolant valve. The headers pretty much block off the EGR tube at the head, so I don't expect the EGR to get hot anymore. I'm not sure if the FPR was swapped at that time however.
I plan on replacing the rest of the coolant hoses / delete the rest of the rear heater next time I crack into the cooing system.
Thanks
-Rob
“Landkruzer”
