Wet DS footwell...
NE FL
As I get to know my new cruiser, I've noticed both PS and DS foot wells were wet. After some reading and searching, I found the partial culprit-- a clogged A/C drain line. I saw a drip under the glove box when the A/C was in use. Used a trimmer string and some compressed air, and now it seems to be fine... On the PS.
But....the DS is still wet. Seems to be in the middle of the carpet only, no noticeable edge moisture.
I've checked the sunroof drains and they seem fine. Water pours out underneath the truck as it should.
The other thing I still need to check is the roof rack bolts...
Anyone else have this issue and if so, what did you find? Could this also be A/C related? It hasn't rained much here so if it was weather related, it must be staying wet a loooong time. Windshield seems factory, and no holes in firewall detected.
Thanks all!
