For Sale Western NC: 2003 LC 297K miles- Sold 11/5/24: $5,400 (2 Viewers)
Year
2003
  1. 100 Series
Mileage
297000
Color
White
There comes a time....
PRELIMINARY ASKING PRICE: $ 17,000 (ACTUAL SELLING PRICE: TBD)
Let's figure out what this one is worth.
HERE IS WHAT SHE NEEDS / WANTS:
Wants detailing - clean the carpet and polish the exterior
Needs radiator
Needs Fix A/C / Leak / Charge
Needs Drive flanges maintenance / there is a "klunk" under certain road / throttle conditions
Check engine light for O2 sensor - (intermittent)
Needs Water Pump / Timing Belt is overdue
Wants ignition lock fix - this is a strange one as it was fu-barred by a Toyo dealer. (the ignition key can be removed even though the vehicle is NOT in Park)
Wants driver side leather seat (sadly) has a cut or two
OTHER ITEMS:
Cat shields rattle going up hill sometimes
I removed the interior wood grain stuff
There are no third row seats
1 ding from a chestnut? on hood. Some rock dings/chips on front of hood
Dent in left rear pillar from previous owner's daughter's softball
Dent in right rear bumper from stupid basketball goal 4 weeks before moving out of previous house (I had avoided that SOB for the previous 23 years)
Has roof rack
Has trailer hitch
Has ARB front bumper but signal light is not wired up
I have the engine cover thing, but not presently installed
There are no lockers
Tires: Michelin LTX A/T2 275/70/18 Awesome highway / gravel forest service roads (which is all this vehicle has done) There are approx 97,000 mile on these tires
and they are still STRONG.
I am the 2nd owner. Acquired 01/25/16 with 142,578 miles
Maintenance Outline
I need to add the most recent missing oil change docs.
11-21-23
Front wipers - rainex
7-17-23
at Larry's
Replaced brake pads all 4 corners with pads from Marietta Toyota
Greased drive shaft
Miles: 282,111
$213.50 (200 labor)
4-5-23 276,655 miles
at Larry's
Replaced all shocks with OEM toyota
serviced A/C system
tightened leaking coolant hoses
3-15-23 275,700 miles
new battery diehard platinum advance auto
3-8-23 275,518 miles
Rotate & Balance tires
1-1-2023
Replaced air filter
6-2-21
replaced wipers with trico from advance auto. 24" flex TRFLX and a 22"
10-22-20 244,553 miles
Replace O2 sensor
Replace spark plugs
Flush fuel system & injectors
12-17-20 246,699 miles
Replaced radiator and hoses
Replaced T-stat
Replaced timing belt & water pump
Replaced oil pressure sending switch
Power steering flush
Brake fluid flush
Fuel system flush & Injectors
Replaced valve cover gasket
Transfer case service – drain & refill diff.
12-29-20 245,000 miles
repaired failed tranny cooler hose that was cut by the fan,
replaced all new tranny fluid
5-16-20 238,602 miles
Changed oil and filter- 5w30 ext'd perf high mileage
Mobile M1-102A
5-15-19 219,875 miles
Changed oil and filter- 5w30 ext'd perf w/ Mobile M1-102A
10/28/18 208,413 miles.
New battery interstate from fire stone - 30 month warranty
6-27-18 200,750 miles
Front end alignment at Firestone
6-26-18 200,740 miles
Tires Michelin LTX 275/70/18
6-24-18. 200,700 miles
Replaced shocks with OEM Toyota
Replace rear rotors with OEM Toyota
Replace rear brake pads with AutoZone Duralast Gold
install anti-rattle spring on front brake pads
6-14-18
Replace heater tees with brass.
topped off with Toyota red coolant
3/9/18 194,349 miles
Changed air filter
SERP belt OEM Toyota
Idler pulley OEM Toyota
Tensioner assembly OEM Toyota
Fan bracket tower and fan pulley AISIN
Topped off coolant Toyota red
8/31/17. 185,724 miles
Oil & filter change
5w30 ext'd perf with Mobil M1-102A
04/23/17 175,740 miles
Oil & filter Change
5w30 Ext'd Perf with Mobil 1 M1-102
Also changed air filter HPR8918
04/14/17 174,219 miles
Exchange brake fluid
Replace front pads
warped rear rotor per dealer
11/12/16 162,500 miles
Oil & filter Change
04/20/16. 148,096 miles
Oil & filter change
02/26/16 144,851 miles
Interstate Battery
01/25/16
Purchased
142,578 miles
12/1/15 141,696 miles
Castrol Lube by previous owner
Oil & Filter Change
Lubed Chassis - sealed
Air filter - replaced
PCV valve replaced
Cabin air filter
checked PS fluid, coolant, trans fluid
checked Serp belt
checked battery
checked brake fluid
Oil Filter MO3614
GTX High Mileage 5w30
Air filter AF5305
06/05/15 137,607 miles
Timing Belt and Water Pump by Prev. Owner
Tensioner replaced
Serp Belt replaced
1 gallon antifreeze (toyo red?)
O2 sensor replaced (part # 89465-60150)
More photos....
Carfax......
Correction: I am the 4th Owner.
Another correction: There is no ARB front bumper (that is on the 80 series that I will list later today). Sorry for any confusion....
Cat shields rattle0
Detailing500
Radiator700
A/C Compressor / Leak / Charge800
Drive flanges / klunk800
O2 sensor - ck engine lt350
Water Pump / Timing Belt1,100
Ignition lock800
Driver side leather seat500
Total deduct5,550
Bumped up /down to new asking price of $10,000.00
Ok, no love for this one here. I will move it to FB Market Place, etc.
Bump up (down) to asking $8,000.00.....
Bumped down to $ 7,000.00.
I will try to send some tomorrow
Adding more underside photos. Exhaust has some rust. Frame is pretty clean.
Replacing radiator and O2 sensors this week with OEM's.
Tentatively sold.
SOLDd 11/5/24. $5,400
