Hi all TLC friends out there!
I wonder if any of you have any experience welding brackets on to the rear axle tubing on the 1982 FJ45?
What I need is this little bracket marked 1. on the picture below. So, I heard that welding on cast iron needs lots of preheating. Which is quite annoying as I have just finished changing backing plates, packing the bearings, resealed the hubs and mounted new break assy.
I'm hoping that the tubes are made of cast steel, so I can cool the areas around the weld, and do some short burst of tack welding. I'm also a bit worried about warping. Is it safe to leave the axle shaft while welding? How to safely drain the tubs from diff fluid? What welding thread and shielding gas to use?
Any ideas and experiences and knowledge around this would be greatly appreciated.
