I've been welding for 18 years, as a Journeyman Millwright. The two factors you need to look at when you're going buy a welder is the amperage output and duty cycle. I understand 220v is not an option, which for your skill level is fine. Look for the highest duty cycle, which tells you how long you can weld in a ten minute cycle period. More importantly however, it really speaks to the quality of the welder itself. Higher duty cycles equate to better internals and longer life, consistent arc,so on. I'm very partial to Miller welders myself, and I've used most of them( Miller, Lincoln, Hobart,century, gas and electric) over the years.
Miller, Lincoln and somewhat Hobart are great names and most importantly have a very broad and well respected service network. That is HUGE. You will, if you do become fond of welding, wear parts out. Drive wheel, tips, the gun, the liner in the gun - so on. I'm sure you understand your need to purchase the highest rated output welder you can for your voltage constraints, you can NEVER have too much welder at that voltage. As far as gas or flux-core is concerned, it will probably easier for you to learn to read the puddle and work on proper gun angle/technique with solid wire/gas. I wouldn't plan on building any bumpers or cages until you know and understand when and why you have problems, like undercut on the toes of your weld, proper bead overlap, things like that. That takes time and practice and asking lots of questions. When you get to that stage, running flux core wire is as simple as loading the spool and shutting off the gas. Solid wire is much nicer for sheet metal stuff anyway.
Hope this some and I wasn't too long winded. Ask lots of questions and remember, duty cycle, amperage, long term part availability and service. Also check out Jody on weldingtipsandtricks.com on YouTube, AWESOME videos!!!! Amazing help, great source of info!! Can't say enough
