My problems seem similar to those of mjulaw (post date 5/26/06) except that my a/c does not consistently work when I am moving, and not work when I am still.
Here are the symptons:
a/c works intermittently. When it works, it blows very cold air (low 40's). When it is not working, it blows only outside air, however the compressor is still running. It seems that it is more likely to not work when the temp in the engine compartment is high due to high outside temps, or warm engine or both.
I put the gauges on it the other day. When I ran cold water over the condensor, the pressures came to right where they should be. So I replaced the fan clutch to increase air flow. However, I still have the problem.
I will clean the condensor and radiator with simple green as some have suggested.
Any other thoughts on what the problem might be?
