@ 10:45
I don't know about all carbs, but my DGEV 32/36 has no visual on the progression holes, at minimal or maximum idle speed screw settings. Because a carb works on the Venturi principle, it really depends on where the air is flowing to get the negative pressure, not that there is necessarily more negative pressure on the manifold side of the throttle butterfly.
This is a bad photo, but the bottom plate is the primary throttle bore, and there are no progression holes exposed. It is a brand new carb, and there is no wear on the throttle shaft, or throttle bore. Being in spec means that there is a little hole that is right in line with the thickness of the butterfly (but, I can't see it here), and it would contribute fuel/air mix even if the mix screw is closed completely (even though it isn't enough to keep even my 2.4L Z24 motor at idle. The challenge is getting enough air thru these carbs while observing their specification for idle settings - jets can be changed, a hole can be made in the throttle butterfly. The goal is to have a correct air fuel mix, at high altitude, across the full range of throttle.
I get a big kick out of these things, because bit of carb skill, and knowledge, is worth a small fortune in equipment for fuel injection.
