Weather strip
Norfolk, Virginia
I have a 78 FJ40 and needless to say the weather strip around the doors has seen better days. I have looked at CCOT and SOR for replacement and can't believe the cost of a piece of rubber. Has anyone found another company or used something different around the doors?
Thanks, Steve
Steve, I have heard for the past several years, if you want it to fit, seal, and last then you need to go OEM. However, if you think CCOT or $OR are expensive, you may pass out when you see OEM prices.
You might get lucky with a generic universal fit... but I doubt it.
toyota has lowered their prices. I bought my two front door w/s for 77 front doors. it cost me 50 bucks a door. they used to be 65 bucks a door ( with tlca discount) sor is 75 bucks.
also just to note -
the oem windsheild pad is 165 from toyota where as on sor. its like 185
just trying to help you out. if i were you i would def stick with oem
get a tlca # card and go to toyota
If I didn't have bad luck I'd have no luck at all....OEM it is!
Thanks
also just to note -
Thanks for the information, just want the doors to close and seal properly. By the way what is a "tica card"? Still trying to get a handle on all the abreviations used in a number of threads.....
