I don't have a manual for the SR5 so I will throw the question out here on a water pump replacement.
It appears my water pump is leaking from what I can tell I have just removed the radiator and about to remove the belts and fan pulley.
My question is the pump a separate component from the timing belt assembly and can I replace the pump without removing the crank pulley and cam pulleys and TBelt.
I know I'm short cutting and should replace the Tbelt I will do a belt inspection and replace it if needed but prefer to skip this if I can....to many Landcruisers needing work while the weather is nice.
