Wasatch Overland is proud to present the Landcruiser Panel 80.
www.wasatchoverlandshop.com
The perfect passenger rear quarter panel storage and mounting solution that requires zero drilling.
It can mount neatly with or without the factory plastic trim.
Made from 0.125 (1/8") aluminum, the Panel 80 serves multiple functions, it can simply be mounted to the Landcruiser and used for mounting molle compatible accessories, or it can be installed in such a way that electronic components can be mounted to it.
Utilizing every available and useable square inch of the space, the Panel 80 comes with a pre-finished 0.625" (5/8") baltic birch 'sub-panel' ready to mount chargers, inverters, cell boosters and associated components.
The unique pre-slotted design allows for easy and tidy cable management using standard cable ties, even after the Panel 80 is mounted in case you want to add further components.
We were able to mount a full Redarc 2000w DCDC charging system on the Panel 80 and still use the factory trim (rear of factory storage box will need to be removed but door can be retained)
Wasatch Overland Panel 80 - Landcruiser 80 Series Quarter Panel Mount | QPM
Wasatch Overland is proud to present the Land Cruiser Panel 80.The perfect passenger rear quarter panel storage and mounting solution that requires zero drilling, also known as a QPM. NOW SHIPPING INTERNATIONALLY - reach out to us for a shipping quote It can mount neatly with or without the...
- Designed, tested and built in Utah, USA
- Uses only factory holes - no drilling required
- All hardware is included, including additional factory panel pins as they get brittle with time
- 3mm, 4mm allen wrenches and 10mm combination wrench are included
- Standard molle compatible
- Black powder coat finish
- Pre-slotted for cable-ties
- Pre-drilled and threaded for sub-panel mounting
- Panel 80 installation takes about 20 minutes - Installation video is available
- Lightweight - sub 16 lbs including the plywood sub-panel
- Available and ready to ship - no lead times.
- Redarc and associated components are not included - Redarc does not recommend mounting their inverters vertically in damp or dusty environments.
- Landcruiser 60,70 and 100 series compatible panels are pipelined
- We do ship internationally, please contact us for details
