warranty???
Hello 100 class! Just bought a lx 470, 147,000, 18,900.00, I know, paid a lot. I really fell in love with it when I saw it! It is a 2002 black with tan, amazing looking! All service records were available as well as carfax. original lease then owner bought out. local (seattle). The dealer gave us a 30 day warranty. Went to fetch some grub at local food supply. Went to start and after the seat and steering adjusted it wouldn't start?? Then I tried again and it started?? Anything I should have dealer look at??? Thanks in advance. Pics to come! Can't wait until it's mine!!!
Congrats mac 10! Sounds like you found a really nice one! I'm picking up my '03 LC today and can't wait to get her home to baseline. Can't hurt to have the dealer look at it - have you been able to replicate the no start condition?
The morning after I bought mine, a 2000 LX, I had a similar issue. Turned out a battery connection was loose... Check the simple things first.
...via IH8MUD app
Had a similar issue - was the negative terminal. On my 2006 LX the VSE lights flash and the radio antenna resets to the lowest position when the battery is disconnected / reconnected. If you noticed either of these it is likely a battery terminal issue.
No have not been out since, Wow, Good luck on the '03. Probably didn't sleep much last night. thanks again.
I'll check connections today, thank you!
Checked connections at battery, a little loose? turned a 1/4-1/2 on both terminals. Hope this doesn't happen again.
Important to know whether it cranked and didn't fire, or didn't crank at all. If crank and no fire, then it's probably not a battery issue or else it wouldn't have cranked at all. This could be an indicator of immobilizer issue, which is exactly what I have. Seems to be a few members with this issue here.
Didn't crank at all.
In that case, could very well be a battery issue. Good luck with it and congrats on the purchase.
