Warning light - fault codes
Hi guys, I have a 1999 4.2td VW here in the UK. I recently went about taking off the intake where the Exhaust gas recircler goes in to clean it. When I put it all back together the check engine light came on.
I took the LC in to have the codes read as the check engine light was on.
They came up with
1) 24(1) Temp circuit???
2) (33)(3) Intake shutter control circuit?
3) the accumulators low pressure.
I suspect the first one is my problem? When I check the voltage across the connector to the air intake temp sensore it says 4.8v?
Anyone have any ideas?
The car has 204k and Im driving it to lithuanis next week! It is well doen on power since the light came on and I will need those horses!
Regards,
Rohan
Still haven't managed to fix this on the LC - she has just been driving about with no power :-(.
I checked the air intake sensor and the readings seem fine.
Anyone cleaned the fine filter going into the pump? is that hard?
She is definitely not getting enough diesel.
Anyone know a good Uk/London based specialist?
Thanks,
Rohan
