semlin
curmudgeon
well i got my old m10000 installed in the arb but realized i have lost the piece of paper where i wrote down where the pos/neg cables go. I believe the neg goes to the lone bolt on the front of the armature case, and the pos goes to the terminal with the white wire inside the solinoid box. if anyone can verify that would be really great. also should the neg cable go to the engine ground or to the neg battery terminal? I am assuming you ground it right to the block.
incidentily, if the negative cable does go on that bolt then it is a good idea to attach it before you install the winch on the bumper
also, it is possible to install an m10000 on an arb without removing the arb. you just use a couple of ratchet straps and gently bring it in from the bottom.
