Wanted: Early FJ40 speedometer
Desert Hills, Arizona
My speedometer is dying on me. It makes a horrible noise and vibrated until the needle broke off. I tried to lubricate it with with no luck...the problem persisted. I was trying to see if someone (who possibly converted to aftermarket gauges) had one left over in working order.
I just wanted to check locally, before I call Tim Hill and have to make a trip all the way down to Marana to get one. Please let me know if you have one available or know where I can get one.
Thanks for any help.
Dale
602-460-3202
'72 Speedo
I might have what you're looking for and though I'm at the opposite end of the valley, I'm closer then Tucson. :-) PM me.
Ray
I believe a 72 is the same...is it the style that does not have the turn indicators in the speedo faceplate? If it is in working order, I am interested. Is it just the speedo or the entire cluster. I just need the speedo, however, I would understand if you did not want to peice out the cluster.
How moch do you want for it?
Dale
602-460-3202
I have an old style one in the garage, can't remember what year though. I'm all the way across the valley from you also (Ahwatukee).
I have a full control panel from a 71. I haven't tested it but was told it all worked. I'm in Tucson but if you want it, you can have it.
