Wanted Wanted: BJ 60 tachometer
i have one out of a 1983 BJ60...how does $40.00 plus the ride sound...this is for the gauge mounted in the pod in front of the driver
best regards
Gord
lynchmob, do you have the sensor in the bellhousing? As you will need that too.
I do have a sensor in the current setup, thanks. It does not seem to be the case that the tach and sensor only work as a pair though.
The engine/trans I am using came out of an FJ62 3B conversion. They rigged the 62 tach to work off the sensor. It appeared to read correct RPM. Please correct me if I am wrong.
Considering that, what benifit am I going to have using the BJ60 Tach VS the FJ60 tach that I already have?
Does someone have a 3B tach sensor to sell? I could use one for my BJ75 though Im not sure it would work the same as the older BJ60/BJ70 setup. I dont know if the flywheel is set up for it. There is a flat spot on my bellhousing (aluminum) where the sensor should go, but no hole.
Got a couple tachs
the diesels usually have a yellow line before red line...and redline earlier (as I remember) than the gassers.
Anyway...let me know which you need..I do have one from a 3B diesel around somewhere?
C
I guess you may be able to get a diesel shop measure injection pulses to see if your tach is accurate.
Redline is 4100 for a 3b. Can't remember where the yellow starts.
Sooo still need tach?
