Been reading several of the timing belt guides and watched several videos as well, all very helpful and make this much easier. I have a VVTI engine and right now about to remove the harmonic dampener off the crank, so I set the crank to the "0" mark first to double check the cam and crank are lined up before disassembling further.
At the crank's "0" mark on the plastic cover, the two cams are a bit ahead of the "I" mark. I have read that I should really use the metal dimple reference on the 2-3 o'clock location of the Crank for the Crank alignment, not use the plastic cover marks as reference as the plastic can be inaccurate. However to check the metal dimple I will have to remove the harmonic pulley and the plastic cover first.
Do you guys think everything looks okay here to start removing the dampener, or did the previous owner not do this right?
I'm thinking as next step, I'll move the cams so that the "I" notches line up, and then remove the harmonic dampener, and then check if the crank notch is matching with the metal dimple on the engine.
My thought is to not trust the crank's plastic cover marks right now. Note I removed the spark plugs already, hoping that will relieve some cam tension when I remove the belt. I read for VVTI, we have to move the cams to the "T" marks first before removing the belt, as that is where the tension is least (to avoid kickback of the cams).
