I have not seen a satisfying final solution for this issue so I am starting a new post:
Issue: VSC light and alarm on wide sweeping turns just over 30MPH and dangerous VSC brake engagement in dry conditions. I experience this on lower speed (30+) situations like cloverleaf interchanges, also on highway driving (70+) on long mountain curvy roads like I90 through Idaho and Montana. The VSC should not be grabbing this early given the perceived yaw being experienced.
Vehicle: 2001 LX470 @ 200,000 miles with AHC removed and replaced with OME shocks, med. Springs and Heavy T-Bars with 1.5" lift, differential drop. Steel bumpers, roof rack, 18" wheels and 33" tires.
Diagnostics Via Techstream and confirmed by Lexus Dealer (See attached PDF):
1. Checked all wheel speed sensors for normal operating parameters and cleanliness.
2. Checked Steering angle sensor for operability.
3. Checked Yaw sensor for operability.
4. No DTC codes encountered.
Actions so far:
1. Calibration memory reset and Zero Point Calibration of sensors.
2. Test drive with Lexus Master Tech and techstream connected.
Dealership assessment: All systems are functioning as designed. The yaw sensor is picking up a -18 degree pitch over 30mph and begins the VSC warning. At -20 degrees the skid correction begins. He believes the lift and extra weight on the vehicle is causing it to yaw more than factory spec. Theoretical solutions to change the spec that they came up with were to check with Toyota to see if the Landcruiser VSC/ABS ECU module has different spec and would allow more yaw before engaging. And another idea to get rid of VSC altogether is to install the Yaw sensor upside-down so it would send a null value.
I am asking for the collective wisdom of the forum to help build out a good thread that we can put in the FAQ on this topic especially if we find a definitive solution. If the dealer assessment is correct then anyone with a heavier than stock rig should be experiencing this issue. I don't believe that to be the case.
Actions so far:
