voltage regulator adjustment need for agm battery????
moncton., nb. canada
hi guys., 1980 fj40., 40 amps alternator......just put in agm red top battery(2 months ago) pamphlet with battery says needs for charging 13.8 to 14.4. my voltage regulator worked well with a regular flooded battery.....but a bought an agm for safety (i thought) . when daytime driving my battery stays well charged up but when i drive at night with lights on and fan ., i check my battery an i find it at 12.34 so well below the 12.87 full charged.....my question is can i adjust my VR to raise the amount of charging w/o damaging my wiring an charging my agm as needed? your input would be very welcome as usual thanks...ps my 2018 f150 with agm battery goes up to 14.5 at least when my headlights and accesoiries are on.....i know we can't compared both but....just saying...
Just the factory headlights.. or some others as well? The heater fan is a big current consumer.
You may be reaching the limit of your 40A alternator.. a DC clamp meter is invaluable in a situation like this. I would not be adjusting your regulator prior to assessing current draw.
Sorry, I can’t answer your AGM question... but, should you elect to look into your VR, Rudi (@bj40green ) describes it and explains how to adjust it here —> Voltage Regulator (ext.) / How it works
Remember you have to be turning at least 2000 rpms to cause the VR to tell the alternator to charge... I presume you are turning at least 2k rpms at night...
You might also consider LED headlights/lights, to significantly lower your electrical draw.
Is that with engine running or not running? What is your ammeter reading with lights & fan off and on? Engine running and not running?
low voltage leads to higher amp draw. 12.34v is not low enough to damage circuits, but it is lower than I would want it. agm batteries require a higher charging voltage than wet cells. charging an agm at a lower voltage will shorten the life of the battery.
i changed my VR and with all acc. on (1200 rpm) i get 12.87 volts on my multimeter....will see if that enough to keep my agm battery happy...thanks guys.....
H4 headlight on high beam., fan on max. , and wiper on..
