Visor Organizers
Overland Tailor
Boltripper
Birmingham, AL
Website
www.overlandtailor.com
The Overland Tailor Visor Organizer eliminates the mess of receipts, pens, note pads and miscellaneous items that plague our trucks. The organizer is a perfect way to get things just where you need them.
Made with all U.S. Sourced Materials and Overbuilt with 1000D Cordura, Mil-Spec Hook, Loop and Webbing, the organizer is guaranteed for life. Loop panel on the front for patches along with 1" webbing spaced per PALS specifications. A Kevlar/Poly zipper pull can be tucked into a webbing slot to keep the zipper from dangling when you drive!
Designed with (3) attachment straps, our organizer stays put and doesn't sag like a granny when loaded with gear.
  • Available in Overland Tailors standard colors (Black, Medium Gray, Ranger Green, Coyote and MultiCam)
  • All materials are U.S Made, Berry Compliant with the exception of the YKK zipper and pull (Japan)
  • The organizer fits the 80, 100, 200 Series. 70 Series fits test is pending~
Starting at $38.50
Use the code MUD10 for 10% Off~
More information can be found here:
Overland Gear and Equipment
Compromise Elsewhere~
LPCm8KfT0alhkZhFII3j28rMXiMgWpiNBDhKyOfjSVKfOE-UdbOANPL6LI0X7I6xCibvpjg3SgYhuko20IPMiUc0FpaXdQwpXt32ZGH5vRBN7ohE1JU5mXvErk4g1qM45kEKREiLuQ=w2400
zBwN2uG5T-cQ7OCD1_QuNnpqRWxPCu4EstqpyTXTM91nevpSyWzLgdQpLe_Z2Xh2M98ozsNvK8M2nGbMHSovAanEMBzu62_WC4YHFZYdP3L0_blvlMXq6hcf6lGUQ577qdqMAbxXlg=w2400
fe_wN70wghMgdwbYqbHpasTLggDumSHmiWYHrl3aFfXj2OOh3suOkTvN6ns7z3q_2q7b2LdzXAei8_-ZtPf2pI-Q3iCXIshwlgpwG8pt4G_iaGUSooFLpMaenliGOA1NtGsKGC8xoQ=w2400
QamCii5-_IK-UVuKbqU3Z8O2sagoxpXiuYMprRUE0TqwH3z7hkv23yYsHXLUk2kw_bV-PByTFnt3N0dK_3h25jQpzhEew5YSd6vdVFyGDHS0XlYFDSmCJWro8lDzMYsnRZT9n2qLCg=w2400
You should show one on a visor...
Just checked out your site.
The Dirt Nap Tarp is great. I might have to pick one up.
Thanks Yonah... I'm back in the shop on Sunday, so if you need anything, just let me know.
John
