- Joined
- Jan 30, 2009
- Threads
- 5
- Messages
- 113
- Location
- 10 N Main St. Troy NH
- Website
- www.drcustomwerx.com
I know this is last minute but not everyone can be the first to hear about it..
We will also be having a private trail ride hosted by big dogs on sunday so bring your rigs!!
Check out our facebookBoulder Bash Facebook
a short video of past events:
https://www.facebook.com/video/video.php?v=453597679103&comments
Longer video:
Boulder Bash 2010 - Car Videos on StreetFire
and a few random photos.
Clarke County Fair Grounds reserves the right to modify the rules and regulations for safety, environmental, and any other valid reasons at any time during the event.
Liability and indemnity waiver
CCFG reserves the right to require all individuals competing in the event to sign a Liability and indemnity waiver prior to being admitted into any area of the competition.
Each participant of the event acknowledges the following while competing:
1) That he/she will at all times while riding in the vehicle will wear his/her approved seatbelt and DOT approved helmet.
2)That the owner/driver certifies that he/she has inspected their vehicle and certifies it to be in safe good mechanical condition
3)That he/she has informed him/herself and spotter to all rules and safety regulations set in place by CCFG and has attended the drivers meeting.
4)That the driver or any other person participating in the event may at anytime bypass any obstacle or area they feel uncomfortable or unsafe driving through.
5)That driver and spotter is at least 18 years of age. OR 16 with a license.
6) That driver/spotter must attend drivers meeting prior to event
7) That driver/spotter must wear suitable footwear. No open toed shoes.
8 ) That spotter is not allowed to touch vehicle while wheels are in motion.
9) That all fluid leaks will earn you a time out until the problem is resolved. You will not be able to continue until then.
10)Spotters will not be allowed to wrap rope or straps around any portion of his/her body during the event.
Modified stock class is intended for well-built trail vehicle modified using readily available aftermarket parts. The intent of this class is to stay within factory designs to showcase the ability of stock type trail rigs. Any rules or restrictions needed to maintain the spirit of this class will be implemented.
All axles must be mechanically differentiated. No hydrostatic drives.
No Rear steering axles
Both differentials must use some form of 100% locking device.
No portal axles will be allowed unless stock from factory.
No Coil-Over shocks are allowed.
Body must be full bodied OEM factory recognizable trail rigs. No tube body built off OEM frame. Some trimming of body is allowed such as fenders and corner panels. There is to be no trimming of hood, rockers, cowl, or firewall. No expanded mesh, lexan, or plexi-glass cut outs will be allowed on flooring or firewall.
Frame must be OEM type. No tube or partial tube frames are allowed.
Power Steering must be stock configuration. Hydraulic assist is allowed. Full hydraulic steering is not allowed.
Suspensions must be stock configuration design. Example: leaf from factory. Leaf for competition/ IFS or ,3 or 4 link from factory. IFS or, 3 or 4 link for competition. Stretching of wheel base is allowed by up to 5 inches.
Tire Size is 38” or smaller based on manufactures sidewall stamping. All DOT approved tires will be allowed. NO COMPETITION COMPOUND or agricultural/tractor tires will be allowed in this class.
Full Roll Cage is required. OEM bars are approved with built on front hoop.
Battery Tie downs (No bungee cords or ratchet type tie downs)
Functional seat belts
Fire Extinguisher
Front and Rear points of attachment
Operational Winch
Winch weight
Coolant over flow canister
UNLIMITED CLASS
Vehicle requirements
The Unlimited class is intend for the most aggressive vehicles in the 4WD community today. Anything goes in the class. You can run whatever size tire you like because your probably too over built to run in the Modified Stock class. The only restriction for this class is that your vehicle must meet all the safety requirements.
Full roll cage
Full locking Differentials
Winch and winch weight
Battery tie down (No bungee cords or ratchet type tie downs)
Seat belts
Front and rear points of attachment
Coolant overflow canister
Fire Extinguisher
Mufflers are required
Longer video:
Clarke County Fair Grounds Boulder Bash
Rock Crawl Rules
Safety Guidelines
Clarke County Fair Ground's primary interest is to enhance safety for spectators and participants as well as promote rock crawling as a motor sport. CCFG makes no representations, expressions, or implies that compliance with the rules and regulations will guarantee against injury, damage, or even death to spectators, participants, and vendors. These rules and regulations constitute the minimum acceptable standards for competition and are intended as a guide for the conduct of the sport. The primary responsibility for safe condition and operation of rock crawling competition rests on the vehicle owner, driver, and spotter. Everyone associated with the sport of rock crawling must share the total responsibility for the competition. Rock crawling is an inherently dangerous sport. Each competitor assumes that risk when he/she participates in the event. Think safety first.Rock Crawl Rules
Safety Guidelines
Modified Stock Class
Fire Extinguisher
Operational Winch
Winch weight
UNLIMITED CLASS
Full roll cage
Seat belts
Fire Extinguisher
