Parting Out Virginia 1985 FJ60 Toyota Landcruiser PART OUT (2 Viewers)
Virginia
  1. 60 Series
Hey there everyone.
I just picked up this 1985 fj60 for parts. was already someone else's parts truck once upon a time. But still has some decent parts depending on what you're looking for.
Let me know If I can help you source anything. Also have an entire building full of parts if you need something that's not seen in the truck pictures.
I would know what shipping is until it’s packed probably expensive tho. Welcome to message me about it tho
Do you happen to have a bell housing, inspection cover and transmission crossmember?
Bellhousing yes. Which one you after 3f one? No cover. Which cross member are you after? Might have it depending on what you need.
What condition is the dashboard in? Assuming this is the blue color scheme. Also interested in a few trim pieces: driver side interior door handle trim, both front fender side light reflectors, rear cargo light, and a trim plate on the inside rear upper door. Possibly the rear carpet too if in good shape. Thanks
I should have most of that stuff. No good dashes. Message me and will talk it though. Maybe send of pics of what you need also
I just acquired a 1984 FJ60 and it drove home but it's a heap. Here's a wish list so far...
1. Alternator. OEM Internally regulated 55A with single pulley in known working condition.
2. Alternator mounting and tension adjusting Hardware. I do have the cast iron bracket that bolts to the engine as well as the radius-ed adjustment bar.
3. Fan Shroud (Carbon Steel). I can make mine serviceable but someone decided to cut part of it away at some point and it will always be ugly.
4. All battery tray parts and hardware. (Rt. Side of 2F engine bay)
5. Air Pump Adjuster Bar. The one that bolts to bottom of P/S pump bracket (17318)
6. Air Pump Tension Adjuster (17317)
7. Tension adjuster bolt (90119-08264)
8. Power Steering pump complete with reservoir, cap and pulley whether or not in working condition.
If you have any of this. Let's set something up.
Thanks,
-Dan L.
How good is the core support?
Thanks
Dave
