VIN plate of my HZJ 79
The VIN is explained here
Vehicle Identification Numbers (VIN codes)/Toyota/VIN Codes - Wikibooks, open books for an open world
Im not sure about TJ,but I think the M = 5sp R=standard model S= naturally aspirated(non turbo)
W= European model.
The T,J might mean it was a cab chassis with no tub
From here,but its a bit out of date and has no reference to the T and J
TLC FAQ - 12.0 Production Codes
The O58 = white paint, LD1=interior trim,A02B is either the t/case or front diff size and type??
You are probably aware you have R151 gearbox
From this site,its american and has not been updated since 2003,so its not really for a HZJ79 ,but most of the info is there.
TLC FAQ - 14.0 Decoding your ID plates
Nice camper you have on the back Fred;)
Hi Fred.Im starting to think the A02B is the style of diff and the ratio. Anyone else know?
I found an english owner trying to decode his 105 series and he had the diff code "A04A"
It seems they have some relation to the American made Toyota 4wds.
Gearratiosanddiffs
If Im reading it right ,for Freds diff code ,A = equals the type or size of diff ,02 is the 3.58 ratio and B is the 4 pinion open diff.
Although I cant recall any landcruiser having a 3.58 diff ratio
ao2b is the diff, ratio is 4:3 if it is a standard 1hz cruiser
turbo cruiser has 4:11.
and 79x diffs will not mate to a earlier 40/60/75/80x due to axel splines different
Thanks for that ,I thought they were 4.3.
How about A04A from a 105 series?
