VIN check finally moving to Denver
Zionsville, IN
So after I sold my two beautiful land cruises bc well Indiana sucks for off roading, I'm being relocated to Denver and so I'm back in the market for another 100. I found an 03 locally can someone pull a VIN check for me? JTEHT05J632045671
Thanks in advance.
you can do it yourself on the toyota owners' website. add the vin and check service history. Last service I saw with your vin was at 127K...no mention in service history of timing belt replacement, at least at a toyota dealer.
hth
Steve
I would think you'd have better luck adding it to the toyota site than a carfax or whatever for main't history. I've seen great carfax and nothing on toyota and vice versa, but if they did have it serviced at a dealer in any capacity, it oughta be on the toyota owners login in site. Good luck.
The history sold me on my current 100 series. Before I bought went to the local Lexus dealer, they printed out entire history. Between that the carfax and my personal inspection I was able to make a buying decision.
And the advantage of getting a printout at the dealer is that it also shows services declined by the owner when recommended by the dealer.
I agree on mine they did every service but when it came time for the timing belt they did not want the water pump done, but then dealer contacted the owner during the timing belt service and said water pump was weeping and recommended changing it. Owner agreed and water pump was changed. Like you said gives more info.
