In my '99 Cruiser I've had a high frequency harmonic vibration noise coming from the engine area. It sounds like two thin metal plates vibrating against each other. It's worse when I first start it up and accelerate lightly. It doesn't occur under no load (unless on first start up) or under a steady load. It is not related to engine speed. And,since it typically only occurs while underway, I can't get a look at it while it's happening.
A friend had told me that it was the heat shield plates over the catalytic converter, but it's definitely not coming from that area (the sound is much more forward, in the engine, even front of engine area). Any other ideas?
