Well i got my 1HZ'd 60 going and it made the 1000 mile trip to Clemson. (see thread in Int'l Board). I ran really well but i have a couple clunks and noises i'd like to address and would like some advise on where to start.
1) First of all there is a vibration over 55mph some where in the driveline (not felt in the steering wheel) during the "load transition" between acceleration and decelleration. If i am off the throttle it only hums a little (not too bad, but there) and when I am on the throttle heavy it only hums too. But when the throttle is depressed just a little it really vibrates badly (especially over 55mph). I think the first step is to replace the U-joints and then maybe the the driveshaft (rusty). thoughts?
2) Also, there is a spuratic clunking and squeaking in the left front end when making tight turns at slow speeds. A lot of things are probably worn up there, but the truck tracks pretty straight on the highway no wonder or pulling, pretty tight steering, but the alignment appears to be off slightly. The wheel is turned maybe 5 degrees right while driving straight.
Where should I start? The vibration is a big one, i can live with the clunking for a while... any ideas? TIA
