VGRS, VSC - No check engine light (1 Viewer)
Australia
Sorry I could not find correct forum for my car. I currently own a 2008 Toyota Crown Athlete GRS204, imported from Japan.
TLDR; Put A/C cleaner foam in the cabin air outlet. VGRS and VSC solid light on dash. Scan with a tool and got up a few DTCs. Car drives great, nothing different from before the warning lights! Zero point callibration did not work.
Had my car for two weeks, drives amazing. Absolutely love it, wanted go get rid of an unwanted smell and used A/C cleaner (foam in Cabin air outlet) which fixed the smell BUT.. VGRS and VSC came up solid. No check engine light. Extremely frustrating as everything was good until the A/C clean.
This is the DTC codes
C1289 VGRS Control System Malfunction
C1567 Error in Matching of ECUs
C1733 RR Damping force control actuator circuit
C1734 RL Damping force control actuator circuit
C1785 VGRS ECU Malfunction
B241A Rear Height Control Sensor
B241C VGRS ECU
B2450 Height Sensor Initialization Incomplete
Any suggestions, advice or point in the right direction would be highly appreciated.
