A2B in a TLC said:>>i havent heard talk of BTUs in my research but MPG was identical with diesel WVO or BD
Well, that answers the question and its good news. Thanks.
Has anyone personally approached restaurants about the availability of their used oil? Do they pay for pick up? Is giving the used oil back to the supplier a part of their contract?
Has anyone had experience with adding kerosene or gasoline to the SVO instead of heating in a separate fuel tank? A friend and fellow Criuiser owner tells me this will work. He has run diesels at his work using this "cut" mix.
BTW, new canola oil is just $1 Cdn per litre at SuperStore. Already cheaper than current diesel prices.
Bruce
Radd Cruisers said:Only draw back with the Webasto is you must plug your rig in at night before using.
lowenbrau said:Am I missing something, Rob? The point of the Webasto is so you don't need to plug in, ever.
I had a chat with the Espar rep at the Canadian Offroad Expo this weekend about this very concept and he thought that, with a valving change, you might be able to run an Espar off pretty cold veggie oil. Even if you couldn't, it would only mean a very small diesel tank to run the furnace for an hour before startup in the morning. Many of us do that already. Make sure your coolant lines run in a bundle with the fuel lines and you shouldn't need to flush the lines at shut down.
VTCruiser said:in terms of BTU ratios, i have heard BD is only about ~5% less than fossil diesel, not sure about WVO. keep in mind BD can also have better lubricationg properties and higher cetane ratings.
Radd Cruisers said:I wonder if it was Mustard Seed, that stuff was said to have very good cetaine ratings?
A2B in a TLC said:Michael,
Where will you place the additional tank in your 70?
Thanks,
Bruce
MiniPigg said:there are actually some plant oils that are being researched that have a much better and higher cetane rating. I cant remember the plant oil being used in the last study I read (2 or 3 years ago) but it looked rather promissing. Only downfall was the oil was expensive to get.
Ive run mostly B20 in my diesels (which I sold and am now dieselless but hopefully not for long). I did notice some power loss but my fuel economy remained about the same. Also it didnt smoke much during startup. As for lubricating properties... depends on what research paper you read. Ive seen both sides of the arguement... some say it has just as good if not better lube as dino and other say it lacks. With what I was running I didnt see anything negative. One rig I ran with B20 for several thousand miles before I sold it.
As for now I am still between SVO and homebrewing some B100. Ive done a ton of reading on both.
Dogsled said:Speaking of additives:
http://edition.cnn.com/2005/WORLD/europe/09/14/germany.catfuel.reut/index.html
Purportedly, 20 dead cats will fill a 50 liter tank. That's taking "put a tiger in your tank" a bit far, don'tcha think?
