For Sale Various 70-series parts - used & a few new.
SNLC
OCD
Supporting Vendor
Boise - Idaho
Website
www.snlandcruisers.com
I have a lot of 70-series parts available, almost all are used. These are parts I have replaced in a build, nothing I am selling is nonoperational.
All electrical parts are 12volt.
Wiper motor: $100
Relays: $15/each and I have most all of them
License plate light assembly: $20
Inner door handle assemblies, brown: $15/each
Outer door handles: $20/each
Fuel filter assembly with warning switch: $75
Ignition barrel w/keys, diesel with glow selection: $25
Ignition switch: $20
Window crank handles, brown: $20 for the pair.
Cargo sliding window frames, no rust or damage: $60/pair These are not for a 73 or Troopy
E-brake handle, brown: $30
Turn Signal/headlight switch assembly, ground wire needs repair: $25
A/C-heater blower motor: $50
Fan, no clutch, it is direct drive: $25
There is more, I will list and add pictures when I get a chance.
I have some new parts I will post up as well with part numbers.
Pictures to come.
Cheers
Hi, Do you have any glass? Looking for the rear most sliding glass, left side. Thanks
No I do not, you can get it from Toyota still iirc.
Cheers
hey, can i see the license plate light assy.
Do you still hve the license plate light assy?
License plate lamp, I didn’t recall there was paint on it or the wire connector had been cut.
So $5 for it plus shipping, it did work when pulled. You could rebuild this if really motivated.
Cheers
I also have a rear brake kit that includes most of the ebrake hardware as well. Lots of meat left on the shoes. Drums included and they are within spec. Rear bump stops included for free.
$100+shipping
Cheers
Do you have the clutch master? If so, Out of what 70 series?
Any chance you have a RHD 74 hand throttle assembly
