It's not - only adjustment screw is for idle mixture.If it's like an MGB's carb,
what happens to the motor when you pump the brakes?
Assuming everything else (manifold, gaskets, HAC) is working correctly, then the pri. main jet needs increased.generally speaking, it is lean under cruise. it runs lean most of the time above ~2000 RPM.
WOT, i can see it go toward rich with accel pump squirt, but as i hold, it slowly ticks back to lean.
need larger jets?
