Hi guys,
I've decided to replace my valve cover gasket / plug seals and clean the throttle body while I'm there. Now that I have all the necessary bits off, cleaned, and safely laid on the garage floor, few questions though:
1. The distributor gear and its surrounds look very brownish (and somewhat dry) comparing to the rest of other internals, including the timing chain, which seem to be well lubricated. Is this normal?
2. Throttle body is thoroughly cleaned. I did not find any crud built up in any of the ports. However, I only looked through the ones that are visible/disconnected (ones on top). Is there any others that I should be aware of? What about the intake manifold side? (Also, the big middle hole on top of the manifold is blocked by the throttle body. What's it for anyone knows?)
3. The two half moons look clean with no leaks. Should I touch them?
I appreciate any help/tips that you could throw in.
Thanks in advance,
Frank.
Thanks in advance,
Frank.
