If lash is reduced beyond a reasonable amount, several things occur, all of them unpleasant. First, the valve timing is changed slightly, and this may affect performance, and emission outputs. But there is an added complication: The exhaust valve stays alive because it's able to transfer a fair portion of the heat it absorbs from the combustion process directly into the cylinder head when it's resting on its seat. As clearance is reduced, the valves spend less time on their seats. This means the exhaust valve(s) has less time to give up its heat, leading to anything from detonation, pre-ignition and engine overheating, to a warped or burnt valve...........
Just saying.......... take it with a grain of salt............
