Vacuum pipe issues
Help!!!!! can anyone please tell me where the CORRECT positions for all the vacuum pipes go on an '87 13BT motor (BJ74), after a long rebuild I can't remember where they all go?
looking at the FSM Engine Repair Manual for the 13BT (Mar. 86) you have to look refer to FU, (which may explain the lack of response), but it really stands for fuel system. and that depends on which lines you want to align and within which system. ...... specify if you still need a hand.
https://forum.ih8mud.com/diesel-tech-24-volts-systems/132335-need-help-13b-t-2.html#post2079455
Thanks Heaps guys, thats exactly what I was looking for, I've been using an aftermarket manual, which is next to useless but I,m pretty sure I can work with what you've supplied, that is if it stops raining this weekend, I'll keep you posted.
Hello again guys, well it stopped raining long enough to get all the pipework done,
next is an electrical issue with the ignition,but thats another story,the only pipe that I can't find a connection for is the one right at the bottom of the toyo-diy diagram( in the ATM box) it's attached to the filter cannister(90917-10049), does this vent to atmosphere or am I missing something?
