Is it necessary for the 1FZ-FE?
A little context, ill explain more than I probably need incase I label something wrong. The Valve cover has two PCV hoses: One to the intake plenum, plumbed with a 1 way valve. (Exhaust side) The other is open between the valve cover and BEFORE the throttle plate. (Intake side)
My understanding is that one allows metered air INTO the crankcase and the other pulls air OUT of the crankcase and back into the intake plenum for burning. However, BOTH hoses are pulling vacuum??? Which really isn't surprising considering there isn't a way one valve on the intake hose, but obviously this worked for 30+ years until the engine was rebuilt & reassembled recently.
I found a picture of a RHD 80 that someone had routed the intake hose over to the base of the air filter box, but there wasn't any explanation as to why, but I wondering if its because theirs was also pulling vacuum on both hoses? I guessing this would solve the problem since the vacuum is probably less at that location that directly in front of the throttle plate. Except that now that engine would be getting unmetered air. Right?
So, I'm thinking about installing a K&N PCV filter on the intake side of the valve cover and a filtered VTA catch can on the exhaust side of the Valve cover. My question is does the 1FZ-FE NEED vacuum assist in scavenging the crankcase or will the crankcase vent naturally?
