SOLD VA - Tundra/Sequioa TRD Big Brake Kit
6840
Old Timer
Virginia
Website
www.orion-ventures.com
Kit fits 2007-2015 Toyota Tundra and 2008-2015 Sequoia. Approx 30k miles on this package. Includes rotors, 6 piston calipers, and pads with ~1/2 life remaining. The massive 16" rotors will require 20" wheels to clear the calipers.
From the Toyota TRD Site: The 323 x 32-mm. patented, directional AeroRotor internal cooling vane design induces greater airflow to cool the rotors, helping shed heat from the system and ensuring the brakes are ready to absorb heat during the next stop The application-specific, one-piece rotor design features non-friction surfaces, which: Maximize corrosion resistance and ensure durability under the harshest conditions Reduce maintenance requirements and simplify service Special cooling vane configuration eliminates resonance modes of the rotor, reducing the likelihood of brake noise—ensuring comfort isn’t sacrificed for performance Rotors’ cross-drilled friction surface: Helps enhance initial “bite” in wet or rainy conditions Assists in removal of consumed pad material or debris Provides an optimized friction interface for consistent performance Provides optimal balance of temperature capability, friction level, pedal feel, dust and noise for performance driving.
These are in SW Virginia. I can ship Fedex ground for ~$80 depending on where you are.
EDIT - $1100 for the set. $80 fedex ground shipping or I'll meet you for local pickup in SW Virginia
I guess that would help... not sure how I overlooked,,,
$1100
interested.
Are you sure they are 16" rotors? Can you measure them to be sure?
I saw posts in the past for 323 and for 406 rotors. So which ones do you have?
Can I get a picture of the calipers other side?
I assume all threads are in perfect condition, right?
Have we replaced rotors? Do you know if there are replacement rotors that are not drilled?
Are the calipers 4 or 6 pistons?
Thanks
They are definitely 16" rotors - see pic.
Not sure about the 323 vs 406 question. I don't see any numbers stamped on them.
Caliper backside pics attached.
Threads are perfect. these use a different thread pitch vs the factory calipers, and I am including the TRD mounting bolts.
Have not replaced the rotors. 30k miles on these, close to time for fresh pads but rotors are good. Don't know about non-drilled ones, I've never looked.
Definitely 6 piston calipers - see pics
Thanks for the pics.
Looks like the TRD calipers kit comes with stainless steel lines. Do you have those to for sale or are you keeping them?
If you're keeping them do you know if the regular lines fit the TRD calipers?
I am leaving the lines on my truck. But, I'll ship the kit for free and you'll have $$ to buy a set.
Great!
Last ask: can I get a picture of the side of the caliper where the hard line connects?
Thanks
no problem. I marked them L and R when removed, but that would also be obvious when installing and connecting lines.
