UZJ100 4.88 gear change packages - all parts needed for $1099
Status
Not open for further replies.
Letsgomoreplaces
Gear & Axle parts for ALL Toyotas new or old...
Washington
Website
www.letsgomoreplaces.com
4.88 Gear Ratio change package for 1998 and 1999 Toyota Land Cruiser UZJ100 series with Factory rear Locker.
The kit includes:
Front & Rear 4.88 ratio ring & pinion sets,
Front & Rear install kits w/ Pinion bearings, pinion seals, cruch sleeves, shims, nuts, etc.
Rear Carrier case and ring gear nut & bolt kit
$1099
For 91-97 Fzj80
$659
or more basic
F & R gears & basic install kits (no bearings) $459
This is a complete kit that includes everything you need to do the gear change on these vehicles. Call or email me for info on trucks w/o factory locker. We also have ARB Air lockers. Other ratios available.
carrier
The ring gear side of the case has adequate clearence for the larger shafts, the small hat can be retained from the 100 series as it is the same dimensionally but has a larger bore for the 32 spline shafts. The hat is machined so that the carrier bearing journal shares the same center point as the o.d. of the hat so it wont give you run-out. Some 2-piece carriers (other applications) are two separate castings that are machined together and are matched.
Status
