Ok Pros,
I know some people had some strong opinons about this, but here are the updates.
1991 FJ80, intial MPG 9 range, completely went through front end (with parts list provided by Dan-Thanks), (very little grease by the way) MPG 15, adjusted badly needing valves MPG 16, installed the part time 4wd kit from Marks 4wd and installed Borlo stainless exhaust, MPG 19 range. Have to do one more tank to be sure. Had a lot of different variables in this tank than the rest of the tanks. The steering is better with the part time kit, the increase in speed from taking off from a stop is noticablly increased. Had to play with the shims to adjust the bearing in the transfer case (which Marks 4wd said I would not have to) but hey nobody is perfect. Overall good experience with the part time kit.
So that is the update and i will let you all know the final MPG.
Cris
Cris
