Upcoming brake/fluid change suggestions. (1 Viewer)
Edmonton Alberta
Planning on getting all 4 rotors/pads swapped out, will also be doing brake fluid change.
Which brake fluid type is recommended for a 2004 LX470 and how much is needed?
i use Valvoline DOT 3/4 Synthetic , from Walmart. Seems to work pretty good. I would get 2 to make sure you have enough. It's a good idea to flush out all the old brake fluid once every 2 years
Also inspect the flexible brake hoses. Rear has 4 hoses and front got 2. I found lower 2 hoses at the caliper in mine have some cracks.
I use Prestone DOT3 on all my cars and it works!
