I've been struggling with an occasionally working horn in my 2000 LX470 for months, and it finally got to where it never works. I read all the horn threads I could find in the forum last night and went out to try and isolate the problem, i.e. check fuse, horn relay, etc...
Before even doing that I discovered the following, that the horn works fine when the key is not in the ignition!
Digging further, the horn works at all times (even with the key in and running) except when the steering wheel is zoomed out.
i.e. tilting the steering wheel up or down does not cause any problems...but unless it is zoomed all the way in it does not work. If I pull the lever/knob to extend the steering wheel even a quarter inch towards me the horn no longer works. If I return the steering wheel to the closest point to the dash the horn works again.
Any suggestions as to what the problem might be here?
