Ultra Gauge and 100 OBD II "Gauges"
I finally got my second Ultra Gauge OBD II reader connected this weekend - the first was stolen the second day I had it.
I noticed the Ultra Gauge has quite a few more "potential" gauges that it can display than what is showing from my 100, like evaporator pressure.
I assume this is because the 100 doesn't support all of these "potential" gauges, but is there a source somewhere that I can cross check this against?
Also, the Ultra Gauge is saying it doesn't find a fuel sending unit so it can't automatically determine fuel level - I find this strange and hard to believe.
The only programmed gauge I'm using, and it works perfectly, is the transmission temp. I like to keep an eye on that, even though to date it's never reached anything close to dangerous levels.
It has to signal through OBD port to be read by the UltraGauge...
I do the engine temp, engine load, mph, mpg, intake temp and a few others. I wish it had a way to read the FuelSender as that would be great....also voltage. :(
You are not able to display voltage ?
mine does
